I'm trying to figure out what this black plastic box is under the dash/column of my 79 pace car (originally 4cyl turbo). The box is unmarked on the outside and has a cover held on with 2 screws. Backside of cover is marked "2L7-0133" and the word "PUGLISI". There are, I believe, about 7 wires going to a grey plug. Wires are multi colored and all solid (blk, rd, yellow, maybe orange and green) except for a couple. I think striped wires are brwn/wht & grn/wht.
There is a circuit board inside. Somewhere, I saw the marking "Japan" and one of the components in the board is marked "SCHRACK" with "RU 101900" below it.
Is this possibly an aftermarket replaced part? Maybe an anti-theft/alarm system? There was no siren/horn on the car, but I do see a small red light that was added nearby at the lower drivers corner of the dash.
I'm trying to clean up some wiring issues. Previous owner had added 3 toggle switches under the dash. When I got the car, I could start with a key. Ignition switch is good, but somewhere, I lost power to the trigger wire going to the starter relay. A few yrs ago, I hooked up a push button switch as a temporary solution.
